we all know.....Moab is officially cancelled. We'll never know if you would have made it...![]()
Copy that.we all know.....
and LS Swap?I could have it driving today if I wanted to. I have the dash wired up, I am working on taking it apart and painting the rusty metal frame on it now that I have no rush. I'm also planning to refresh the 8274 too. I'll go on record and say that I would have been ready.![]()
Now that you have all this extra time....gonna fix the knocky knocky?
Part numbers were the same between 1997 TJ and 2004 LJ when I looked and ordered my replacement parts.I'm sure the bore is about the only difference. I'd assume the LJ has a larger bore?
My LJ has an external proportioning valve, so may be the same master cylinder. I was looking at booster part numbers.thats weird, I wonder if they are different for rear drums vs rear disk brakes? does the size of the booster mean anything? I need to do some research.
The volume of vacuum it can hold i believe
