many people take them off and use the brackets as bar pin eliminators on the rear shocks.
Which is the wrong thing to do. Remove it all and throw it in the scrap bin. The use of the axle side mounts as an Upper BPE is not a good idea bc it rotates the shock and puts it in bind. The rear shocks are mounted at an angle and as the axle drops they rotate on the pin. The best BPE I have ever seen is a small piece of angle with two holes drilled in it. Some even put a small piece of flat on the back side to gold them together. IIRC I used 1" x .25 or 1.5" x .25 angle to make mine. You cut 4 pieces about 1" wide and drill 2 holes in each. Done. Love the bolt! LOL!
