The 8.8 is a strong axle. It is not quite as cheap as you think thouh. Yes you can get an axle for 160 at pull a part, but it will be 3.73 gear ratio, so you will have to regear. That's about 5-600 without a locker. Add a locker and your easily over a grand. Then you need to decide if you are going to keep the factory short arm set up, which will run about 300 to have the old brackets removed and have the tj brackets added, or go with a 4 link that will greatly improve ride and off road performance for aboit a grand. My 8.8 is going to cost about 2500 once it is all said and done and that's with a 4 link and Detroit truetrack limited slip, not a locker.
I'm glad mine came with an 8.8 in it:grin:
