TJ E-Brake Not working after brake job?
trailworthyxj
Just put new wheel cylinders, shoes (riveted HD monroes), and springs on my TJ Dana 44 rear. For some reason, the e-brake won't work now (and yes I checked to be sure I hooked everything up correctly). They are also adjusted properly (shoes and e-brake cable). I've read about similar problems on other forums where the drums ended up being the issue, even though the brakes worked great. Doesn't make much sense, I know. Anyone else experience anything like this? Thanks.
you say you adjusted it properly, can you adjust it tight enough so that it wont move? Does adjusting it change anything.
Adjusting the shoes doesn't seem to do anything E-Brake wise. There is tension on the e-brake lever when I pull it up and I know the shoes are moving because I pulled the lever with the drums off a few times and checked both sides. I'll have to play around with it a little more this weekend. May try and get my neighbor to check them out for me. He's been a GM mechanic for 20+ years. I'm sure he's ran into something like this before.
