97TJGUZZY
You have any other pics of his suspension? Did you build frame mounts or use some prefabbed ones? Curious if you pushed the axle out any and what length arms he's running. I saw some pics on fbook but hadn't checked.
I've thought of fabbing new lower brackets but I burned the genright brackets on last winter so its a little late to try and mod the brackets as they are welded when you get them and most of the bracket is press formed and its a bit hard cut and rework without sacrificing structural integrity. i didn't think about the frame placement piece but believe that the bracket would have to have been mounted behind the rears to get the angle right, but they are as far back as possible against my belly up skid. I think I'll probably end up dog legging the lowers to compensate for the angle and a little frame clearance.
http://www.polyperformance.com/shop...-Control-Arm-Frame-Mount-Un-Welded-p-698.html
those are the ones I used
