Yep, I believe it pushes the y pipe back about 1.5". Once the spot welded tab from the rear of the pipe is removed, it slides into the catback.
Installed the cam locks on the front axle during lunch today
View attachment 19720 View attachment 19721
did you have to cut out and make it a slotted hole in the control arm bracket for it to work?They came with the kit from JKS. Supposed to take place of geometry brackets or control arms.
I've had an annoying squeak since the lift install. You could hear it when rocking all 4 corners and going over bumps. Finally isolated it last night to the passenger rear swaybar link. The upper bolt was a tad loose.
Also, got to play in the dirt last Sunday!
It is a little smoother for sure and seems to track better on the road.
