Offroad Teardrop
Got the run rails built and started fenders. Then I had to roll out for a wedding in GA. I'll be back at it soon. Still a lot of work to do before next weekend. Also bolted on the new 2.5" lift springs, but I broke a built whe I disassembled it.
Only took a few pics
We burned the midnight oil last night and at 11:15PM, the teardrop rolled out of my shop with fenders and guzzy with a hastily wired brake controller and visegripless battery terminal.
I took a shot under of the "cable management".
I didn't grab any of the fenders.. they turned out decent.
Didn't get many pictures in the shop last night. I plan to grab some this evening when we get packed up. We skinned them in textured ABS plastic to look like a jeep flare.
Also, trailer brakes are awesome!!! My jeep stops way better when pulling the trailer than normally haha.
did you seal the small gap between the fender and the camper or let it be? I couldn't tell from picture.
currently its open, I havent decided how I want to do that yet. I'm open to suggestions. its about 1/4"-3/8" gap. I was thinking some kind of rubber seal like for door jambs.
Any plan to put something on the inside of the fender to prevent the aluminum sheet from getting damaged?
Sent from my XT1096 using Tapatalk
So before you ding, bump, or bang it on the trail I suggest the completely mental approach. Pick an inconspicuous spot, whack it with a ball end of a hammer and you'll never worry about getting that first scratch or dent!
if you enclosed the inside of the fender i almost wouldn't worry about it. There are all kinds of weather/rubber seals in all kinds of different profiles out there you could use.
