np231j issue
Ok so I finally got around to rebuilding the tcase and got it installed, but now it will only shift from part time to neutral. No 2wd or full time. Could it be the adjustment is messed up. Have only driven it forward and reverse for like 5 feet trying to get it to shift. I will try and drive it further distance to get it to shift. Anything else it could be?
Thanks for any input/help.
Is the linkage set back up correctly? Did you replace the shift fork in the correct possition when you put it back together?
I will try and answer both of you. When I installed the tcase I think the shifter got moved in 4low. I haven't tried driving it yet, the yard is to wet to drive on.
