Same problem I had. When I changed headers on my jeep. I used torque lock nuts and the solves the problem.
I ordered some all steel lock nuts today.Same problem I had. When I changed headers on my jeep. I used torque lock nuts and the solves the problem.
I need to try this on the ferd. She gots a little ticky tickyLocktite probably isn't going to work, you use heat to remove red locktite. You might need distorted thread nuts if new bolts doesn't fix it... I might would even try to tighten them when they are hot (expanded) and let them cool.
I have a clip on the tailgate to fold the antenna down when I drive it to work. It hits every one of those horizontal beams, and if it gets to swinging and hits one when its forward I'm afraid it would break it.Good thing you have access to tall garages. the Schools garages are smaaaaaallll. I shrug my head everytime i go under a cross beam in my Wrangler. The CB antenna hits every one
Intake is finished up and looks like it will work perfectly.
Started on oil pan skid. This tube will get the front of the pan past the exhaust crossover and give me something to build supports off of.
1.5 square. The struts to the frame will be 1" square.is that 1x2 or 2x2? can't tell from the angle.
