Jeep 7" Round Head Lights
I was looking to order all this stuff myself, but I have to admit I am struggling with the cost for H4 headlights. Are they really worth it? I have always hated the sealed beam performance and I want the new rig to have actual useable headlights without trying to slap HID in a non HID housing. LEDs are way out of budget and I don't think they will look right. Which ceramic connector did you get? All I can find are basically no name Chinese ones.
That was almost exactly what is in my cart right now except the ceramic adapters. I am building the harness so I was just looking at ones with pigtails. Even still I might only use the housing and put my own hardware in it. My goal is a harness without splices unless I am doing 2:1 or something like that. It helps to have a huge box of duetsch connectors under my desk. There are a couple places I am stuck though and generally it is around lights. I have to just splice that stuff in.
I did the ceramic plug swap, rewired with 12ga wires, and powered through a pair of 45a relays several years ago now. It's a very big improvement.
Yep, no complaints. Might end up doing a new heavy duty power harness at some point but no problems.
Sent from my SM-G955U using Tapatalk
how much brighter/better is the low beam (80w) vs 55w? Do people mistake that you have high beams on and flash you?
The low beams look great, I have less people high beam me than i do in my bone stock 150 with the factory leds. I actually think the lowbeam pattern of those housings is great, i don't typically even use the high beams, the lows with the fogs look great!
Great! Ill pass along the info.
I did the same mod and love it. Low beams are great and the high beams do great on dark back roads around the house.
Had a headlight go out last week, just placed the order for this setup, its only $118 now for the 5 items listed above.
