He Keep it Clean tho'....
going to make plans for a traction bar? those xj springs turned backwards might allow for some axle wrap.
If you are new to the crawling scene what makes you want to stretch it?
From what I've read it all depends on vehicle and the driver. So I guess I won't really know until I try it.
You will need the traction bar. If you don't plan on bent leaves and broken driveshafts all the time.
Personal experience? I guess I'll make plans for some type off anti wrap bar.
yes, with pretty much any spring over yj you will need a traction bar.
Thanks man. Working on a wrap bar right now. Hopefully I'll weld it on this weekend, or 1 night next week.
Sent from my DROID RAZR using Tapatalk 4 Beta
Wrap bar, after looking at several different designs. Unsure about the mount to cross-member so I have the heim and a bushing mount to try out.
Axle bracket is 3/8", traction bar is 1.5" square tubing 1/8" wall, cross-member is 1.5" square tubing 3/16" wall.
Looks good, what size is that hiem though? all the force of from the axle will be acting to bend the shank on the hiem joint.
5/8" heims.... Supposed to be rated at 11.5k lbs
