Gulches 12/21
  • Thread starter Thread starter 01tj
  • Start date Start date
Was mason running a stock tie rod? I thought he had heims and a 1.5"x.25 tie rod.
... I am.
My tie rod Is pretty bent up to the point of where I think I need to replace it. May test out an aluminum one cause it won't be but 20 or 30 bucks more and a chromoly one would probably break knuckles
... I am.
so it was stock? If you need another one to get you by I have a few stock ones.
So what thickness was that thing? That bish just cruppled. I bashed on mine on the 4runner and it never had any issues?? None the less, that sucks.
Not sure when we'll be going back to gulches. I will post up when we do. Some of us will be going to The Compound on January 4th if you're interested in checking that out.
Yea I thought about going to compound but don't know if there is anything there for my rig.
Yew gotcha a bilt rig er sumthin?
Well depends an what you call built.
Mine is a 93 YJ full cage,117inch wheel base, 4linked front an rear, 16inch fox air shocks, TH-350 reverse manual valve body, 203/205 doubler, LQ9 6.0 43sx swappers 2.5 ton rockwells. Full hydro steering. Etc etc. It depends on if you call that built?
