97TJGUZZY
So after this storm it got me thinking a little more about generators. I currently have a Honda 2000 that was able to easily run our fridge and chest freezer and a fan and some lights while sipping gas. What it couldn't do is power my well pump. I'm going to pick up a 240v generator to address this concern. There are few on the market that seem to meet my needs and could possibly even run my AC/Heat pump with a soft start kit. The 3 I've considered are:
Honda 7000 Inverter - Gas only
Predator 9500 - Gas only
DuroMax 9000/9500 - Dual Fuel
I'm looking at the Duromax because of the option to run on propane and its built on the same motor and guts as the predator. The Predator and Duromax are right around the $2300 mark, while the Honda will set me back around $4500.
All of these are significantly larger than my little gas sipping honda 2000 so I'll need to consider having fuel on hand for times when I may need the generator.
The 2000 would run on 2 gallons for 24 hours, where as the 9k generators are looking like around 10 gallons for a similar time frame. Thats assuming you aren't running it at the max. I think with many of these I would need to conserve fuel by only running it for certain times of the day and maybe at night.
So what generator do you have, what do you like about it and what would you change if you could?
