I see.
The trailer from the factory is 5x4.5, same as the jeep. The center bore of the Ravine is too small. If I go that route, I will machine 3 of the ravines I have to fit it, 2 on the trailer and the spare on the back of the jeep. That way the spare could be used on the jeep or the trailer.
How much to small? It may be easier to machine the hubs down to fit a factory wheel. That way you are not stuck on what tire goes where. I know I always try to work my spare into the rotation so that the tread level matches on my vehicle. It isn't working on this suburban due to the stupid steel spare.
Parts came in today so I couldn't resist a test fit.
I was originally trying to use a set of 1.25" spacers. They would have had to been bored to fit the trailer hubs, and the wheels would have had to be bored to fit the dust caps. Tripp offered to buy the 1.25" for when he does his 8.8 swap so I ordered 2". With the 2" spacers, everything fits perfectly with no modification to the wheels, which will allow me to run the Jeep spare in an emergency. There should be enough room between the back of the tire and the box, and it only increases the width 1.75" per side.
I'm not doing well visualizing the coupler....
Looks good Larry.
I think i said "Steve's Tube laser would make this part its bitch" about 25 times.
It spoils you that's for sure. I respect when someone takes the time to make a nice clean part by hand getting the radius clean and consistent. Knew a body guy in Atlanta that was so anal about making parts by hand with minimal tools but the product always turned out amazing, mostly for thing that would never be seen.
I'm interested to see how the hitch turns out. My m416 has a ball and coupler on it now and I've twisted it up once before going through a ditch and had to replace the coupling. I've been wanting to change it to a different design ever since.
So... If i draw up a solidwords model and send it to you.. you can pop us out a hand full of these![]()
