Has anyone seen this stuff?
http://www.bubbarope.com/4x4-products
I'm sure they work fine, but you can get a Keeper strap for less.
I have a 6" Keeper (yes it's HUGE) that I've add for over 20 years.
JP
Are you talking about a Keeper static tow strap (polyester)? Most static polyester tow straps only stretch a few %, nylon dynamic recovery/snatch straps stretch about double, maybe triple depending on the manufacturer, where as the recovery ropes I'm testing and will offer soon stretch up to 30%.
Well you're right. But why do you want soooo much stretch?
JP
I think abrasion is the leading cause of strap failure... Not stitching![]()
Tow/snatch straps (hookless) have worked well for me for 25 years, I see no reason of replacing them with a newfangled stretchy rope.
I've also used straps at the end of a winch line with great success.
JP
As long as the strap does not stretch and you use good, solid, closed connections (no knots) between your winch line and static, non-stretching straps then you should be OK there. I'd strongly recommend against introducing a dynamic material such as a snatch strap or recovery rope into a winching situation. That will introduce stretch and more stored energy which during a failure would become very dangerous with recoil.
:cheers:
Winch anchor straps are made of the same material as tow/snatch straps and have some give too...
JP
I watched Ultimate Adventure and the Bubba Ropes were used quite a bit on there and I was impressed. I cant justify the price right now when I have a ton of other stuff I need but man they would be sweet to have.
