body lift replaced
Well the 3inch body lift is out and new daystar 1inch installed. Think 31" tires will be fine. The bolts were a b**** to get out of the six center mounts. They were frozen to the steel sleeve inserts. I had to cut bolt under body puck then cut the head off with torch to get them out. Had one that nutsert was messed up so removed it replaced with body washer, lock washer and nut. 18hrs later glad that job is done.
31s will be tight on a YJ with only a body lift. Depends on how sagged your stock springs are as to how much it will rub. Also, it will rub less with stock backspaced wheels.
31s on a stock yj with no body lift
