1994 Toyota Land Cruiser FZJ80
195+K miles runs great.
6cyl, auto transmission
6 inch lift
285/75/16 BFG A/T tires. Excellent tread.
Factory electric Lockers
Front ARB Bumper
Rear swing out tire carrier
12,000 lb. WARN Winch
Snorkel
Optima Glue Top Battery
K&N air filter in factory housing
All windows work, sunroof works, AC works, Cruise Control.
New Radiator. (truck was not overheated, old radiator just sprung a leak)
Rear Engine heater hose replaced.
Interior is in good shape.
Front seats have nice tight fitting covers (seams split on front seats)
Rear seats have scratches but are fine. 3rd row seating.
Issues
Has dents from trail use and paint has typical burnout and flaking.
One rust hole in rocker, but no other rust areas
Exhaust leak.
Engine Valve seals leaking some oil, will puff smoke only at the stop light.
This truck drives excellent I never even offroaded it, i got it already pre-dented,
I just drove it on long trips with the family and it worked great.
$4000. Email me if you are interested.
Wow - $4750 is a good deal for someone to pick up. Clean the actuators, rebuild the front axle and you are good to go. Even has factory e-lockers front and rear.
Front and REar lockers are operational.
Replaced Cats with test pipes, but left flanges so you can put cats back on if you want.
I can't believe this thing hasn't sold yet! I've seen this thing in person, and, like Dan said, the only real thing wrong with it is the dents. If I didn't have the XJ I would jump all over it!
BTW Dan, you should update the original post to show that the locking diffs are now operational.
