06TJX
PRICE DROP:
$700.00...
Really need this out of my Garage. I just do not have the room or the time....
Got a new car, and Wife says 4 vehicles are to many. Its either the Cherokee project or the Wrangler, and the TJ is NOT going! So, I am putting it up for $900 obo. Here is what we have:
1987 Cherokee White exterior (paint not great) and grey interior. It also comes with an almost entire red interior
4.0L inline 6
5 speed manual with brand new clutch
new brakes all around
Jeep had an engine fire, and I have been slowly getting parts.
Here is what it needs:
I think that is about it. It is in great shape, but still needs a bunch of work to get it running. If you are trying to make a trailer toy, this could be a great starting place. It has most everything needed to get it running, and it has a clean title.
I do not want to part out as I don't have time to do the work.
Shoot me a PM if your interested. Give me an offer...worst I can say is no...Trades are acceptable as well, so let me know what you have.
$700.00...
4.0L inline 6
- It has had the entire engine wire harness replaced to the ECU,
- most all the sensors on the block replaced
- replaced Throttle body and sensors
- replaced the intake assembly
- replacement AC compressor ready to go in
- replacement fuel rail (still have old rail)
- Replacement Heat shield (still have old shield)
- replacement soft fuel lines with about 5 feet of hard line already on it. Just needs to be be flared to old hard line.
- Replacement Master brake booster
- replaced fuel injectors
- replaced serp belt
- have electric fan to install
- replaced the HVAC control panel
- I have a replacement ECU and full wire harness from the ecu to the tail lights
- replacement fuel line needs to be coupled to the old lines
- AC lines need to be replaced
- Needs all vacuum lines installed
- Needs drivers front door window
- needs Drivers quarter panel
- needs hood ( i have 2, but both are pretty beat up)
- Valve cover needs to be pulled off and the valves need to be cleaned out from the fire.
- needs battery.
