97TJGUZZY
On board air, there are tons of ways to do it: CO2, ARB compressor, viair, etc. They all provide pressurized air to fill your tires.
I'm more concerned with what you do with that air. So the Airing down process is easy and fast in multiple ways, but when its time to air up its a little bit more tricky. For the longest time, I used a local gas station or someone else air source. Then I had CO2 and now I have a viair. They all work for providing air.
My CO2 and my Viair require me to hold a air gun trigger to let air flow. I'm looking to make it where I turn on the compressor, hook it up to my tire and then walk away till it turns off at the set pressure. Then possibly use 2 hoses so that I can do 2 tires at once.
I'm thinking I could use an adjustable pressure regulator with 1 inlet and a Y on the outlet and just set the regulator to the pressure I want the tires to be. That way when its to pressure, the pressure will build in the input line from the compressor to the regulator and the compressor will shutoff.
Anyone have any ideas or think this wouldn't work?
https://www.amazon.com/gp/product/B...0921cfaec42044bf6a774b65ec81e4&language=en_US
