does it corrode? what goes bad in it?The last couple trips we've had power, but I noticed the battery seemed to be getting weak when setting up or stopping at rest areas. I was about to buy a new battery, then remembered @Twilliamson had mentioned the battery disconnects failing. I had ordered one a few days ago to have a spare and it showed up today. The switch had gotten hard to turn so I went ahead and swapped it out. Problem solved! And another one ordered for a spare spare.
The switch itself is "sealed" and I didn't take it apart to investigate further. But it felt crunchy when turning so probably internal corrosion.does it corrode? what goes bad in it?
Chineseium ... Everything mass manufactured is crap...does it corrode? what goes bad in it?
It was pretty fancy. You might need to wear a vest and get Madi some fuzzy boots.We've been wanting to check out Jeter. Worth the drive?
We hit grandads last year and enjoyed it but the bar and bbq at jeter was enticingwe normally go to grandads, but this one was 25-30 min closer to the campground we were staying at.
David and Teresa got a BBQ plate and said it was good. I would definitely go, just go early and plan to spend a few hours.We hit grandads last year and enjoyed it but the bar and bbq at jeter was enticing
