Are they pine? If you have some dead pine use that after you get it started and it will boil the water out and let them burn. Depending on size if they are small enough I put them in my burn furnace. A 55 gallon burn barrel with a stand of angle and expanded metal to hold them up off the bottom. Also has 2" hole saw holes in the bottom so ashes can get scooped from under it.i'll have to let them dry out for a while, but i will probably do that eventually.
I also built a grate from scrap rebar. Roughly 2’ x 2’ Set it on concrete blocks and shovel the ashes out.
Yes that is one of my burn barrels. It is actually an old barrel that the bottom rusted out. My new one sits on blocks with the holes in the side and bottom and has a shelf in it to hold the wood about 12" off the bottom.so your barrel is just open on both ends and you set the grate and barrel on blocks? thats a pretty good way to do it.
You have seen the forcast? Friday - Monday rain....Hoping to get this container moved in this Saturday!
Supposedly Saturday is no rain.You have seen the forcast? Friday - Monday rain....
I have 2 if I can find them both.Yeah, anyone have a few bottle jacks local?
