I keep two of the ball type bungies to strap them to the roll bar when not in use.extinguisher mount looks good. Do your rear belts flap like crazy on the road? I swear in my TJ they were never this bad.
I strapped mine with one of those, guess i need to get another one.I keep two of the ball type bungies to strap them to the roll bar when not in use.
Ever since I swapped the booster and master cylinder, the reservoir has leaked. Either the cap threads were not good or the seam of the tank leaked, but fluid had to be low or the seam would be wet every time I drove it. I swapped caps with no change, so I swapped back to the old nasty yellow original resi.
Also noticed my rear bump stops are done, and I must have hit something pretty hard in Moab...
I had developed an exhaust leak again. Passenger side collector was leaking. I tightened it up and seams like it stopped the leak, but I ordered a set of better quality gaskets than what comes with the Chinese headers.
Ever since I shed some weight in the front with the aluminum 5.3, she's been riding a little high up front. Especially with the hardtop, car seats, etc. I didn't want to be accused of the squat or anything, so I threw a pair of 3/4" spring spacers in the rear too. I'm 1/8" higher in the rear as it sits now.
I had noticed lately that the rear tires were getting into the plastic fender liners more often, and it was bottoming harder. Not sure what would cause that...
So she got a new set of Crown replacement bump stops too.
Air bumps ftw!The chevy ones I got from you a few years ago for the front of my TJ are doign that already also.
Little pre-DBBB maintenance for the LJ. Sometime recently something caught a wiring harness under the rear and broke a spade off my trans cooler temp sensor. I was able to get a new sensor here today and swapped it out, and tied the wiring up a little differently.
I've had a clunk that I could feel but never find for a while. I drove it up town aired down and with the sway bar disconnected and felt it several times. When we got back, I got Burgundy to shake the jeep and I saw the lower shock eyes just flopping around on the bar pins. Autozone had a set of bushings on the shelf so swapped those out.
