97TJGUZZY
They have to be... They are just tucked up pretty high behind the dash.
Interesting, Thats a noteworthy discovery if its on all TJs.
That would have eliminated my fuse tap and wire nut. Well... just the fuse tap actually.Interesting, Thats a noteworthy discovery if its on all TJs.
I wonder if that is a Sahara feature?
So who makes a top post battery mount battery disconnect that isnt a giant pos?
These never seem to work long term.
I really wish someone made a Blue Sea style Post mounted switch.
I was really trying to avoid that, dont really have a good place to put it without making super long cables, I ordered one tonight, im gonna see if i can make a top post adapter to connect/mount the switch directly to the battery...Ordered some new lathe tools as well, so.....can you mount a blue sea style switch?
Ordered some 5mm brass, probably machine it all on my manual mill.how thick is the brass?
Looks good, what’s the kit gonna run?Dad came over today and together we made loads of progress on my projects. First and most importantly we got the AC installed all of the lines connected, Oil put in the correct places and sensors installed. Im going to take it into work this coming week and pull a vacuum on it and fingers crossed charge it up. I did a partial warm up with the new heater core installed and was starting to feel heat. I might actually enjoy driving this thing once its all back together with functioning climate control.
Moved on to my Battery disconnect project. Dad and I looked and discussed several option when he had the eureka moment! We came up with what i think is the best way to do a proper disconnect on a TJ/LJ. So much so that i really need to draw it all up and maybe have some kits made. Here is what we came up with (PS having a machine shop in your shop is freaking awesome). 95% of this was eyeball engineering, so its not a perfectly perfected design, but i'm super duper happy with it. The feed between the battery and the switch is only 4awg wire, but at a foot long with a 300 amp draw your still talking less than a volt of drop, its gonna be plenty big enough.
View attachment 19581View attachment 19582View attachment 19583View attachment 19584View attachment 19585View attachment 19586View attachment 19587
Also made some good progress on my overhead communication / camera / lighting console, but didn't snap any photos of that yet.
I was thinking about $100-125.. Everything you'd need. If there is some interest i might put some effort into it, likely after moab.Looks good, what’s the kit gonna run?
