https://www.offroadsc.com/threads/just-another-green-98-tj-sahara.6394/#post-78602do you have any other pics of your rear axle swap that show your new brake line locations. I want to run new lines when I put mine back in.
I didn't know that was a thing (vibration dampener) Now I need to see if I can find one at the junker. I have a slight vibration from 50-55 that i've just lived with for years. Any negatives other than just added weight?I would also try putting the vibration damper back on the axle and see if it quits. Made a huge difference on my explorer. When you put the rear diff back together did you put the smelly ford additive in it? If not that is highly recommended as well.
So, Im on the fence about the LS additive. Im putting amsoil back in it, and they say it has the additive built in...I would also try putting the vibration damper back on the axle and see if it quits. Made a huge difference on my explorer. When you put the rear diff back together did you put the smelly ford additive in it? If not that is highly recommended as well.
Don't suppose it will hurt anything, I'll grab some tommorow.id Run the smelly ford stuff. That stuff has always been preached pretty heavily by people who run fords.
I think it did... I just need to try it in the upright position, because right now its hanging down pretty low.did the weight contraption help any? I actually found mine from years ago buried out in the RC rock pile when I was looking for a concrete paver last night.
Well the wife approved the addition of AC to the Jeep.. $469 from Rockauto for everything but the drier mount $30 ebay and the re circulation door $45 from mymoparparts... Looks like DIY is gonna save me about 40% of the Jeep Air Kit. That also included a new heater core. I will just need to make a decal for my slide style controls to know where the AC works.
Current Situation...Only cussed once at the Blend Door Cable clip, that thing was a mother, to get out.
And Found these neat wires, didn't know they were under there.
They have to be... They are just tucked up pretty high behind the dash.dang! are those factory?
