I use a 27mm deep well and a couple short extensions. You can't get one long extension in there, have to stack one in at a time.Its waaaay easier with that right socket.
That sounds fun with the adaptive cruise...Not my rig, but put a Warn Transformer on a "special" work truck yesterday. Custom Paint Matched carrier, Adaptive cruise relocation, etc...
View attachment 19132View attachment 19133View attachment 19134
yeah, I've done 2 now with adaptive cruise.looks like they have it covered with a relocation bracket though.
I’m not sure. After I put the rear springs on, it showed up. I adjusted the front coils a little to compensate and it helped but as everything settled, it has gotten worse. Very noticeable now. So bad that the front left front is setting on the air bump.is the pimp lean a Coilover setting? or do you need a spacer for one of the rear coils? Whats causing the lean?
I know I didn't put them in by any type of driver/passenger labeling, maybe I missed it. I will get under there tonight and check. I can't even remember what brand they are, I know I had to try a couple different ones. The first ones didn't work out because of the extra weight in the back (armor and toolbox). I ended up getting an HD version of something, just can't remember what.I can't recall which springs you installed, but my OME coils were labeled Driver/Passenger to account for the torque twist of a Jeep. Is it possible you have them backwards?
So..fixing my ac has turned into: all new ac components and lines, new radiator, new fan, fan clutch, belts, hoses, heater core, pulleys, tensioner assembly, water pump, thermostat, thermostat housing, power steering pump, power steering lines, and a power steering cooler. Oh and exhaust manifold bolts and gaskets. Been a good opportunity to clean up wiring, fix broken/missing bolts, re-insulate the blower motor box, and tidy up/refresh anything else I see. Boy that escalated quickly...i mean, it really got out of hand fast
