Good buy and an even better cleanup job.
is it a rolling stool with tool drawers under? Looks pretty cool.
I made this little doohickey to hold up my drivetrain today.
Nice. I plan to do a separate trans mount when I do the swap so the skids can be dropped easily.
Nucanoe Classic 12What model is that?
Nucanoe Classic 12
I grabbed it up for $300 used if I remember correctly. Seats 3, but I'll only be using the pedestal seat. Dam nice boat, easy to paddle, and stupid stable in the water even with that tall seat.
Not sure about yours, but with mine I have Daystar motor mounts. They are so stiff the skid can be dropped, and the transmission only says down about 3\4".Nice. I plan to do a separate trans mount when I do the swap so the skids can be dropped easily.
Not easy to find. People don't get rid of them very often.That was on my list but couldn't find one.
Today I got it installed and tested. Working well!![]()
So that's the ucf lopro bolted directly to that, then your skid will clear the bolts?
Exactly. I drilled four holes for the lopro mount and the skid will clear the crossmember. The crossmember is currently 1.5" below the frame rails. The skid will sit between 1.5 and 2" below the frame rails. I'm just happy to drive it right now.
Nice. I'm hoping to eliminate the lopro. Dont really need a flexible mount there with the bushings on each side.
