Ok whats the best place to start diagnosing this thing, and dont say LS Swap....
Runs fine, maybe smells a little rich.
Plug, wire, distributor.
But if it were mine I'd LS swap it.
I just did that a couple years ago.. less than 15k miles. Guess i could do it again.
Mine is a 98 and I had this on the number 3 cylinder. I tried everything that has been suggested and it would come right back. After some research I found out that there was a bad batch of springs for the 98s. Solution was to pull the head and have it rebuilt. Did that and, knock on wood no more problems.
Let's see, I got the Jeep in July of 2012 and had the head rebuilt in September of 2012. Mileage was about 158 kValve springs? How long ago did you do that and at what mileage?
There was a bad batch of valve springs from mid 1997 to early 1999 in both 4 and 6cyl engines.Mine is a 98 and I had this on the number 3 cylinder. I tried everything that has been suggested and it would come right back. After some research I found out that there was a bad batch of springs for the 98s. Solution was to pull the head and have it rebuilt. Did that and, knock on wood no more problems.
It should have been a recall with the number of vehicles it effected. Instead it's no more than a TSB. The TSB basically states that if you suffer from a recurring misfire after verifying the ignition & fuel systems are properly operating, then it is likely a week valve spring, and the head should be removed for overhaul.
With the availability of tools today, a tech can replace the valve springs without removing the head! No need to perform the expensive overhaul, or replace the head, just replace the faulty parts!
Don't get me wrong. I didn't mean to replace one. I would always replace them all as a set. I just meant that there's no reason to do more work, or spend more money than necessary.But my luck is like yours sometime, I replace the first one, then another and another. This way I pulled the head took it to a shop and presto a weekend of labor and I'm back on the road.
The code just said misfire right?I don't know what to think now... I still haven't pulled the plugs and run a compression test, but yesterday i drove it around for a hour or better and the check engine light went off, It almost seemed to start rough but clean up as it warmed up to operating temp. Would a crank position sensor cause this weird problem?
Ok. Ill look at that... I do know i have something wierd going on with the cooling system... i have no heat, but have pretty good flow through the heater core.....If your misfire is mostly during cold start up use a diagnostic scanner to see what the ecm is showing as the engine temperature.
