Now the AC compressor is screaming!So it seems like the list of needed repairs goes up every time I look at it.
Need 4 tires
Steering lower shaft
Steering shaft support bearing
Support bearing bracket relocation
Tie rod end
Steering dampener
Alignment
Front & Rear brakes w\rotors, and E-brake
PSC power steering pump rebuild
Intake filter box relocated
Driver's seat cushion upholstery work
Valves adjusted
Spark plugs oil change
This is after I just had the tensioner, idler, water pump, and belt replaced.
New water pump bearing went bad in a day, and while the engine was warming up from water pump #2, the power steering pump started making noise!
So, what did I do to my Jeep today?
Looked at it with distain!
Sent from my SM-N950U using Tapatalk
I'm so disgusted......
