1999 Wrangler TJ Ball Joints
I was trying to track down the cause of a steering wheel shake at 35-40 mph. I believe my driver side ball joints are shot. I jacked the jeep up and placed a rod under the drivers side tire to lift it up and down. There was play in both the upper and lower ball joints. The passenger side ball joints seemed good. But I'll probably go ahead and do both sides at the same time.
I plan to use these ball joints unless someone recommends different ones.
http://www.amazon.com/dp/B007N6OHI0...UTF8&colid=1IIP30FVC422H&coliid=ILFBIZRI73CAA
What else should I replace while I am replacing the ball joints.
Definitely do both sides while you're under there. Won't hurt anything. And while your under there you can grease all your tie rod ends and check your brake parts. Not much else you can service.
