Thats a clean rig. Whats under the hood?
8 valve or 16? And does it have tcase gears?
What size tires are on it? And are the axles stock? I know you already have the axle gears, but case gears would help you out some in high range for the road and be much lower in low. Also, stock 3.73 ring and pinion is much stronger than 5.13. My dad ran 5.38s in Sami axles and broke gears several times.
The 8v is a torquey little motor.
I think he drives it more on the street and 3.73's probably don't pull worth a sheet on the road in 1:1.
Well dinz. How bout that. Samis are wierder than poo
