Christmas Sale! Garage Cleanup, random stuff
Garage Cleanup, random stuff, some free - Updated 8/7/2015
I'll be adding to this as things turn up, but it's time for a purge, and I'm consolidating my other for sale adds here. All items located in Leesville, SC and can be delivered to Columbia. Feel free to make offers on anything not priced, and will consider trades.
-LJ full steel corner armor with hardware $225 - new never installed, bare steel.
-TJ 2" spring spacers, pair $10
-2 16x7 Soft 8's for Jeep/Ranger 5x4.5 $75
-Trail Gear v belt power steering pulley $10
- G force wrist restraints, 2 sets - $20
-14 bolt wheel bearing socket, OTC 1929. Fit my 2001 Duramax, 11.5" ring gear - $20
- 2" lift CJ-7 front springs. Were run on the rear of my Sami. $100
- 1 set of stock TJ Rubicon springs
- 1 set of stock LJ springs
- stack of TJ/LJ stock control arms $10 each
- stock LJ bumpers $25
- Olympic Reverse-a-bars for LJ $100
- set of '95 XJ unit bearings
- approximately 30" piece of 6" diameter PVC
- trailer stabilizer jacks, 4 @ $10 each
- 87 samurai ecu
- Sidekick transmission bearings, not sure of make/model but was told 95 sidekick 5 speed.
- Rancho My Ride wireless controlled air compressor.
- factory steel wheels off the Duramax with 265/75/r16 Kuhmo tires and center caps.
Free Stuff:
- 1 shock bump stop with the install tool
- XJ rear window vent visors
they are 7.00 - 15's which makes them about 30x8x15. They hold air but are pretty hard. There is a ton of tread left but it's worn unevenly. I wouldn't run them on the street.
That is the diffuclt thing with the old tires. i have seen so many good tread tires, but they are just old. They must be bias ply. :) You could bring them by to the GPW and make it a roller with them.
How much length of the 6" PVC do you have ? Also do you still have the roof rack that was on the Cherokee and if so do you want to sell it ?
Theres a little over 30". It's enough to hold a short side shaft but not long side. It's not the one in the picture, that is 4 inch and has my 30 shafts in it without bearings. The 6" will fit shafts with unit bearings with a small amount of grinding on the tube.
The rack is on my trailer and I plan to keep it.
Bump, added some things:
for the front or rear or does it matter?
I think all 4 are the same on a tj. They're a little beat up. Picture is in the first post. I should have all 4 but I didn't find them the other night.
Found new vent visors for the rear two windows of an xj. Free if anyone wants them.
-Rancho My Ride wireless controlled air compressor setup. Probably could be used for something cool. Make an offer.
- fuel filter for 2001 Duramax
