yall packing the RCs for camp?
I'll have mine.
I gots no steering.. Go figure my replacement parts i had shipped to the house and they are going to be delivered tomorrow.
I'll have mine.
does it run?
I never went and picked up the 3mm bolts for the motor, but other than a battery and putting that in there I dont see why it wouldn't. Transfercase has always felt really tight for some reason.
I'll have some bolts for the motor.
With the tcase, you need to put loctite on the bolts when you put them in and dont tighten them down. Just make them pretty much a little more than finger tight. The tolerances are just a little off on the bearing retainers on them and it makes them really tight when you tighten the tcase down all the way. Mine has been fine with the bolts basically little more than finger tight and loctite. The case halves almost snap together anyway, so the bolts are almost un needed.
I'll bring it then. Maybe I can borrow a little battery from Harvey. Ill see what I can get done to it tonight.
Do you still need any cross members?
