The "moving back out west" shop clean out sale
Will be moving back out west in July, so need to loose a little weight for the movers. Wish I was heading back to Colorado, but it appears that this road it leading to San Antonio, Texas. Good news is Katemcy Rocks is only 2 hours away.
With that being said, here is the long list of stuff for sale. Can bring any of this stuff to the spring offroad festival this weekend.
Backwoods offroad V8 conversion all brass radiator with auto trans cooler in lower tank, about 2 years old but very little use. Has a few spots from where the external trans cooler was mounted, but no leaks or anything that impedes functioning. $100
http://backwoodsoffroad.com/cgi-bin...ad&cat=4&page=1&search=&since=&status=&title=
Pairs of Eibach silver 2.0 coilover springs, only used for mock up: $100 a pair
12” x 200
14” x 200
Pairs of PAC racing 2.0 coilover springs only used for mock up: $80 a pair
12” x 125
14” x 100
New aftermarket stock ZJ power steering pump with reservoir off of a 5.2: $20
Artec front hp60 lower link brackets for short side 60. Brackets have never been tacked to tubes, but are already welded: $35
http://www.artecindustries.com/Dana-60-Lower-Link-Axle-Brackets-pair_p_260.html
PSC JK stock front axle hydro assist ram mount, used for about 6 months: $50
Teraflex JK front frame brace with frame side trac bar drop bracket. Brace has been flipped and has an offroad EVO sector shaft brace welded to it. Currently the fame side brace bracket it still welded to my JK frame but will be coming off in the next week: $
http://www.teraflex.biz/frame-brace-trackbar-drop-jk-front.html
Artec JK rear adjustable trac bar bracket. Bracket it fully TIGed together, but was the first run artec made so it has 5/8ths holes. I have 9/16th weld washer to go with it for a stock rear trac bar bushing: $25
http://www.artecindustries.com/JK-Rear-Tracbar-Bracket_p_348.html
JK currie front leveling spacers and extended bump stop pads. Spacers are for 2.25” lift in the front: $50
Rubicon Express JK rear axle side trac bar bracket, came with a 3.5” lift” $40
Teraflex JK front bump stop extensions: $30
http://www.teraflex.biz/jk-front-upper-bumpstop.html
Artec jeep JK unwelded front adjustable axle side trac bar bracket. This is the one made for their front truss, but also works with the purejeep front truss. This was a bracket from the first run of brackets, so the holes are cut for 5/8ths but I weld washers to make it 9/16ths: $25
http://www.artecindustries.com/JK-Heavy-Duty-Raised-Tracbar-Bracket_p_314.html
Pair of Jeep JK stock exhaust manifolds off of a 2008 3.8L with around 28k miles on them, no visible cracks and where removed for headers: $100
Rubicon express jeep JK front disconnects for 3.5” left. Are missing one bolt, but otherwise are all there: $50
http://www.rubiconexpress.com/Lift-...s.aspx?t_c=1&t_s=101&t_pt=4309&t_pn=R/ERE1143
2008 Jeep JK steering gear, had around 26k miles on it when removed. No leaks or twists in the sector shaft: $200
5 x 17” stock hummer H2 wheels (8 x 6.5) with a few nicks here and there. 4 of the 5 have been clearance for ford 1-ton hubs: $150
Nick is correct I'm in Columbia, or Forest Acres to be precise.
Dang, wish I would have known that the press would get this much interest.
I have a 20 ton press too, but am still using it with the SWAG DIY brake to finish up the latest version of the TJ. I would consider selling it once I'm done with it if any of you are looking for the bigger press.
I forgot to mention that the 12 ton press doesn't come with any arbor plates, as they turned into shrapnel when I was press the rusted U joints out of my stock 60 shafts. There are a few vendors out there, SWAG being one, that make true steel arbor plates that don't become victim operated IEDs when you are using them.
sorry man i forgot i replyed to this and just got a chance to get on the forum....if other people want it let them have it, your kinda far fro me and wont be worth it for the ride
I am very interested in the Jk sway bar e-disco... If it is functional, I would like to make an offer? Maybe one of the guys I know can pick it up and hold it for me if I pay you via PayPal???
The smartbar works great. I honestly think it has been disconnected 10 times or less (more than likely less). Only thing that has been done to it was clearance the link mounting holes out to 1/2".
