tj/zj/jk parts shop clean out
Cleaning out the shop and the following need to go:
teraflex motor mount 5/8s spacers for a TJ. These came with my belly up skid but don't work with my 5.2 mounts: $20
ZJ power steering pump and resivoir with maybe 2k miles on it. This is the same pump for a tj or xj, just requires and different resi with a different return location: $25
teralex jk front shock extenders: $20
Used hp dana 60 4.10 gears in good condition: $40
Used GM 14 bolt 4.56 gears in good condition: $40
Skyjacker TJ sway bar disconnects for 4 inch lift, comes with stock TJ swaybar: $40
ZJ class III receiver hitch, good condition: $40
ZJ and TJ power steering gearboxes. The TJ one has a little leak at the pitman arm output seal: $20 each
JK rubicon express rear trac bar bracket for 3.5 inch lift: $20
Also have complete JK rubicon unlimited stock suspension to include springs, shocks, control arms, trac bars, etc: email with what parts you are looking for.
PM with questions
