is upgrading the bearing caps necessary at all?
I need a slipper clutch disk. I think the same one is used on the scx10 and wraith, If you wouldn't mind grabbing one for me, I'll get it at Oscar. I think it's like $8 bucks.
Well does anybody want to buy some 2.2 iroks? They have maybe 15 battery packs on them at most and ill give you a great deal! While ordering parts today i made a purchase i didnt plan on and put a order in from crawler innovations for their 2.2 Pit Bull Rock Beast 2 combo with their 6.0 Double Deuce foams :grin: So as of right now the parts list in the mail is - 36/14 HD gear set for the front, 43/13 HD gear set for the rear, new hub for the mip shaft, Futaba 4pl transmitter and reciever, Pit Bull Rock Beast 2 with 6.0 Double Deuce foams, Fast eddies bearings to rebuild front and rear axles, Vanquish diff, cover for the front, Vanquish cvd shafts, pack of 10 set screw pins for the driveshaft hub (let me know if anybody needs one) , and my HH motor came in Monday from being rebuilt. Should be alittle different when its all put together again!
Yes, The MIP Setscrews are larger, I believe they could even be SAE, And you cant use the through hole type pins. .No big deal on the slipper pad, mine still works, It just doesnt slip anymore!I'm not sure but I think from what Tripp said, the set screw pins from axial are different from the ones that come with MIPs.
I found the through pins that work with the MIPs and actually go through the pinion like the axial pinions need.
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXUTF4&P=7
Tripp, you could use these too
18.5 ballistic
:That short wheel base with that motor is going to cut some sweet back flips:
but is it on 3S?:
