Cherokee Dana 44 axle swap!
Okay so about a year ago I swaped 86 Jeep wag Dana 44 axles under my 98 cherokee! I used ballistic fab brackets. I have since then upgraded to 1 ton steering with tie rod ends!
I guess my problem I am trying to take care of is that, I have not been able to get full steering or full turn out of my steering. I have the stock pitman arm that was reamed out to fit the tre's
I know others are having the same problem has anyone fixed this problem?
Thanks
the waggy arm gives you full steering but really cuts down the power leverage you have, with a WJ arm its almost as long as a waggy arm but not quite, it gives you most of your steering and its much beefier than the waggy arm.
you can use a hacksaw in a stock pitman arm and cut the four double splines into single splines. Thats what I did on mine. You could also do it with a jigsaw maybe.
X2 on this. Meaders told me to do this on an FSJ arm and it has worked for several years now.
Last one I tryed didn't work so well. If I didnt have other projects on my mind I would just throw full hydro on it, but a new pitman arm should get me by.
