Can't you just order some spindles from parts mike?
You should just run stock 30 outers so you don't have to worry about spindles:
Good luck on the swap. What gears are you running that they were hitting the cover?
The gears weren't hitting the cover, it was the ring gear bolts.
I hear you Mason getting stuff done! What coil spring buckets are you running?
When you gonna start that Ronnie?
Going to start building it up in the garage now, truss coil buckets etc. gonna order the 3/4 heim steering kit, lower control arm mounts, and all the stuff to make my radius arms into a 3 link and then build everything else. Since I need my jeep over break I'll probably start tearing it down right when the next semester begins.
