Unbelievable. The guy confirmed the ratio tag to say 241or and 4.1. Guess what showed up and i was not there when delivered to deny? Yep 241j. I may need to ask a favor of one of you grey rock bound wheelers. This is typical ****. Someone trying to get over on someone. Annese out!
Does anyone know if a Rubicon transmission mount bracket is needed to do this swap? Mine wont work, it hits the case and wont mount flush against tranny. I'm guessing that the Rubicon one is a little different.
TJ case. The Rubicon case has a larger ring around it to house the bigger planatery gearset. Thats whats not allowing my mounting bracket to sit flush against the tranny. Maybe its the fact that I have an AX-15 trans and it was prob never in Rubicons.
I have not noticed an indexing difference and i would consider the size difference to be significant as there is no way to make it fit under a stock skid without cutting the floor like i did or adding body lift or skid drop kit. Im concerned about my driveline angle for sure though. I will be installing a mm lift to help. Im also concerned about vibration because this case is straight slammed against the tub all over. You cant fit a piece of paper over it. Could it be indexed higher maybe?
