Looks like I need a 43/13 Ring/Pinion. RPP is out of stock and was hoping to get the parts so I could have it at windrock. Any suggestions? Or does anyone have something layin around?
Finally got this thing back going. The new Ring and Pinion was a good bit different. The head on the pinion was a lot smaller but I changed where the bearing sat in the housing and it seemed to work fine. It's almost like it needs two now though?? Anyways...I beat on it some today and all seemed good.
Well......... Maybe that was the issue
U only had 1 bearing on ur pinion lol
Sent from my DROID BIONIC
Aite, I got something goin on with the new Ring and Pinion. Don't know if I did something wrong or what but it has a lot of play...
The old R&P the pinion was made different and sizeable larger head wise. It seems to have the same depth though just made differently. Also, the way the driveshaft hooks up is different. The old style had a groove for a set screw and the new one has a small allen head that runs all the way through it. It won't work this way.
Ideas??
