I actually looked this up last night and have it pulled up on my computer. I found two places that will do it 50-60 bucks I believe. One of which is the company that makes the high steer arms like brooks has, google behind the axle high steer Dana 44 and it should come up. Thinking they say throw knuckle or knuckles in a flat rate box ship it to them and it usually goes back out within 24 hrs.
Brooks I know I've asked before, but would you post up pics of your steering set up.
I like that my knuckles have 4 studs instead of 3. Wonder if you can get that done to a stock flat top?
I guess it was designed for the Reid knuckle, but Parts Mike sells them.I never thought about the 4 bolt, is the arm your running Marcus specifically for a Reid knuckle?
Also brooks, why did you decide to run the steering arms you did? I saw on there website they use a bigger spacer then regular which would seem to me you'd loose an inch of uptravel, I do like how it gets tierod out of weigh and seems to be easier to mount an assist ram.
did a little work to the 44 this morning. Cut the old brackets and cleaned her all up. she was a beauty under neither all the oil on it!
gonna try and get the old ball joints pressed out of the chevy 44 today, then most likely call it a day.
anyone else see the all the road grime all over the floor??![]()
Found a pic from the previous owner of my 44 so you can kinda see how the brackets fit.
I bet ur roommate is just loving u with all the car parts in your dorm room
