whose mounts are you running brooks? or how are they set up?
I have the combo brackets from ballistic on my 44 and they send the control arms straight back. I'm hoping with the angled frame mounts it will solve the issue as how i had them mocked up they would be all up in the way of tires. With them on the driver side of the axle it crowded thats for sure.
the control arm mounts on the ballistic kit are angled not straight back. I have installed 3 of those kits and they all work fine on a waggy 44, you just have to trim some of the cast and you need to use the passenger mount on the drivers side and vice versa in order for the distance between coil mounts to be correct.
They're angled at 5 degrees, excuse me. Mine came already on the axle welded up and there is no removing them and reusing the mounts with how you'd have to cut them off if i was to want to move them.
Barnes makes a control arm/shock bracket http://www.barnes4wd.com/Axle-Link-Mount-Shock-Combo_p_260.html
And a coil spring mount although not all together http://www.barnes4wd.com/Coil-Spring-Bucket-Centered-Pair_p_96.html
Sounds a hell of a lot easier to just buy coilovers.
Easier, but alot more $$$
Why not cut some coil mounts off a d30 and just make your own control arm mounts. the coil mounts already have the slope in them for the bottom coil to sit in so your coils don't always looked goofed.
not complicated......
Give us a total $ figure when you get it all done. It'll be interesting to see what it costs these days.
