Well the price is about the same? Actually heims are probably cheaper. If you run that TRE into a rock and it breaks the joint?????? Why not go the strongest route?
Also, on my Toyota I just never had any luck with the TRE. Mainly due to the fact of no jam nut. I ended up having to tack the TRE to the Tie Rod once I put the Hydro Assist on to keep it from not flopping around and coming loose. No strength issue but a PITA.
Hiems are Loud, and get sloppy pretty fast when they are in muddy/dusty environments. They are cheaper and for a trail only rig I would say go ahead, but hell only my Trackbar and hydro ram are hiems and I still have to lube them just like my TREs.
Why no jamb nut? cant blame the TRE for that, a hiem would have the same problem with no jamb nut.
:Hiems are Loud, and get sloppy pretty fast when they are in muddy/dusty environments.
Shoot, Rich had to weld his jam nuts so that the TREs were all bound up to keep the tie rod from flipping. I thought that was weird although the only way he could stop it from flipping at Harlan. Im glad mine didnt do that but it may be because one of my knuckles taper is wallered all out and the TRE has to be hunkered all the way down to keep from being loosey goosey. I am replacing the knuckle now.
That's the same thing mine did. All Toyota guys have issues with that when you add hydro assist
sounds like the ram isnt parallel to the tie rod.
Heim is chromolly. Stronger material. And typically have a better thread from what I have seen. Jay's one ton TRE's were really sloppy when he pulled them off of his white cab truck. Who knows the length of time they were on there though.
Again, it's just my opinion. But I see a chromolly heim and a grade 8 bolt as being stronger than a pressed together part built from a cast type material.
Ruff Stuff 3/4-3/4 here to. Ran them on my one tons and now on my mini truck axle. For as much as they cost it's worth grabbing a spare pack and toss in the box. But I highly doubt you will need them.
what do you mean flipping? if the TRE is required to hold itself straight against some sort of load then its not setup properly
I wonder if there is 2 differant styles of Moog TREs, a low grade and a better one. When I buy them from Parts Mike they always thread in perfect, but when they come from Advance they are a chore to thread in.
