Gulches (pre-Windrock) testing session
308turbo makes an appearance in SC...time to rid yourself of that Jersey plate
Marcus, did you find out what was up with your front hub?
The outer shaft on the RCV was rubbing in one spot on the inside of the spindle. I have read where some will require a little clearancing and some wont. I took it apart and did cleaned it up the inside and put it back togather, but it was raining so I didnt get a test drive in. Ill do that after work today.
Great pics.. I drove the TJ around in 4wd for a while today and no noises.
