Oh I see what you mean about the Tamiya plugs.
I just installed my pump this weekend. I'll keep the info handy in case I run into trail troubles. So if it happens again you could just cut the plug of and twist wires.
Brooks, so your front axle has an ARB in it? How do you like it compared to a detroit or lunchbox locker?
The time for rebuilding my front axle is near. I was just going to rebuild the diff with a detroit and call it good. How do you like the ARB compared to the auto lockers?
my rear has the ARB, the front is a lockright. The ARB is night and day over my old detroit in the rear. I dont mind the auto locker in the front because most times I just leave the hubs unlocked till I need them.
The 8.8 doesn't have a soft locker available so it's the old school hard locker type and brooks is a pansy and doesn't like the jarring:
Seems I hear a lot of trouble coming from ARB owners, I know gillis's issues is from the way the lines are routed.
You ever riden/driven a jeep with a full time locker? You don't notice it after driving it everyday. ARB's are sweet id run one if I had the money but for half the price almost after its all said and done I'd just run a Detroit or likewise and spend the money elsewhere.
I can see towing with a full time bringing the suck but I doubt I'd pull much if anything.
Also I can tell if one rear tire needs a little air because every once in a while if you leave a red light it will pull like hell really hard to the left when going straight then "kaboom" sounds like the dam rear end fell out and all is good.
this is a false statement, if you dont notice an auto rear locker in a TJ you are oblivious, and thats all there is to it.
