Wheel pop?
sometimes when i turn my steering wheel, i get a popping noise which sounds like its coming right off the inside of my tire, the steering gets tight and then once it pops the wheel breaks loose and everything fine, any ideas?
Are you running a locker in the front? Have you check the U-Joint between the outer and inner shafts?
yeah i am running a locker, but thats not it, it sounds like it is coming from the ujoint but i dont know what would be catching and releasing inside of there
Also, something basic to check, have you checked to make sure your lug nuts are tight? That will pop pretty bad.
its on both sides depending on which way i turn the wheel sometimes its the left sometimes its the right, ill check the bearings and lug nuts tomorrow. thanks
Have somebody turn the wheel back and forth while you look for the culprit. Pay close attention to your pitman arm and see if it jumps when it pops. That would indicate a bad tooth in your box
