I don't believe they are the same on the input to the output....different years had different input Splines...and I believe all out puts were the same (excluding Sye's)
Sent from my ADR6400L using Tapatalk
What year and engine and tranny do you have?
It's 23 spline input 27 spline output. If I find a 231 with the same gear ratio on the tag (mines 272) will the spline count be 23 in 27 out or is the only way to know for sure is to remove the tcase?
