irmoxj
That thing cleaned up nicely!
I know in the plumbing section, they have ABS cement, PVC cement and also ABS to PVC cement. That last one might be helpful since it's a combination cement and may work with an odd plastic like that.
You going to turn it into an Unlimited?
That looks good Brooks. I wouldn't try to piece one together personally. But my luck sucks...
Could make some corner guards out of real thin metal to clean up the lines and add rigidity to body.
When ppl do metal work on these, they use solder for the welds?
Did you shorten it even more? That looks to be a good bit shorter than 12".
Gotcha, I was doing some research on that last night also. It looks way better like that. So you just shortened the rear links?
Have you tried ace?
